Heated gloves or grips?
#31
I like the stock heaters on my new Limited, but I've been using a set of heaters called "Polly Heaters" on my 2010 Heritage with no problems in 5 years. The best part? They cost $35. (P/N: PH200) Go figure. Also you can use any Grip you want. These cartridge heaters sit inside the Handlebar. They have two settings: Low and High. Trust me . . . you'll never need the High setting. They were originally made for Snowmobiles. They also have a set now that wasn't available 5 years ago that their web site says is for motorcycles (P/N PH400) for $45. I'd probably go with them as, like I said, I've almost never used the High setting on mine. And yes I have and do ride in some seriously cold weather now and again. Not LA though.
#32
Forget heated grips. Not even a fair comparison. Gerbing makes Harley's electric gloves. Just get a pair of Gerbings. You can plug directly into your bike's battery tender wire (if you don't have one, you should) or, better yet, spend the bucks and also get a heated jacket with a double heat controller. That way you can have heat to only the gloves or only the jacket or both. Believe me ........ you end up saying "Wow! How did I live without them!".
#35
Warm-n-Safe (First Gear) makes a wireless controller for heated gear. Battery powered (CR123 i think) and can put it anywhere on bike or person. Only plug in you have to do is the main power connection to the bike. I have a dual controller and keep it in my windshield pouch. I actually have heated jacket, gloves, liner and socks. Dont always were all of them together, but they are available if it is cold enough. 1 controller channel is for the jacket and 1 is for the gloves/socks. Works great!
#36
Wind is wind, and if it's traveling over your fingers, it's going to strip the heat away.
This sort of thing is ugly to look at, but they work *real* well at keeping the heat in, and thereby keeping your hands and fingers far warmer than you'd expect:
http://www.hippohands.com/Harley%20Hippo%20Hands.htm
#38
Question. 30 Years ago, While serving in the Army, stationed in Germany, My fingers were frostbitten. Fast forward to my new to me 08 Ultra classic I just can't seem to leave home. Driving to work every morning, if it's 55 or below, my 20 mile hike doing 70 turns my fingers numb and white with gloves on. I am thinking either the flame heated grips from HD, (staying with the flame theme)
@ 269.00 OUCH or maybe heated gloves? I see the gerbing's or joe rocket can be had for 140 or so. Any input as to which route to go, plus minuses to either? I see the Joe Rocket has a rechargeable battery operated glove. No wires !
#39
