Street glide factory radio
Mu aux port quit working and I'm riding to Daytona next weekend and would like more then 15 songs on a single CD. Is there a way to do it? I've heard of people putting up to 100 songs on a CD but I'm not sure how to do it or if the bike will even play it.
Anyone done this?
Thanks
Anyone done this?
Thanks
yep, i've done this quite a bit too....just note that for some reason, some songs don't play...it wasn't very many in my case and i'm not sure exactly what causes it...some on here say it has to do with the artwork of the file or something.
CD-R- so you are bruning a "data" cd and the files should be MP3's.
If you use a mac you can do from itunes ( create a playlist, burn playlist to disc)
or Toast which i like better.
for your aux- iron cross is one of teh places that'll fix this- or you can look for tutorials online.
the jack is pulled loose for the circuit board, so needs a quick solder repair.
best to use a rt angle plug for this, less likely it'll get contacted and lever the jack from teh circuit board
mike
mike
mike
mike
Thanks. I haven't tried it yet but I burned one last night from ITunes. I used a CD-R and selected "burn as an MP3 disk" so hopefully it will work. I will find out tonight. I believe there was another option to burn as data disk but didn't say anything about mp3.
Here you go, helped me burn a disc for mine a while back
https://www.hdforums.com/forum/touri...on-kardon.html
Thanks for the link. I'll read up on this if it doesn't work tonight.
sbeast
04-02-2014 03:02 PM
