battery tender not hooked up?
The battery tender fuse is on the dedicated battery tender cable. Nothing else is impacted by it. Nor do any other fuses control it.
Originally Posted by TriGeezer
Actually, the battery tender is a dedicated dual wire usually black cable. Both positive and negative are connected directly to the battery. There is an inline fuse on the positive side, closer to the battery end. Trace the cable to the battery and you'll find the fuse.
Well, I hooked it to the battery tender and the red light was flashing so, I called the tech at the dealership and we tried to diagnose it over the phone.
No blown fuses, everything else is working. And yes, this tender lead is incorporated into the harness on the bike.
I even pulled the screws holding the left side tray on to see if I could find something...... no dice.
I tucked it back under the cover and put the lead on the battery that came with the tender and I'm going to use it that way for now.
Sucks I can't get the factory one to work though.
Funny you ask that.....I have an accessory switch I can't for the life of me figure out. I have a couple of plugs that don't have anything plugged into them but, the switch has no effect.
I also tried the switch with the tender lead...........
OH SHEITE!!!!!!! It just dawned on me that I NEVER turned the IGNITION on when trying to figure out that switch..... heading to the garage now.....
Stay tuned......
Guess what? YOU win the prize! The P&A fuse WAS blown......... It was for the battery Tender AND the mystery switch on the dash!!!!!!
I found the "plug to nowhere", touched the leads from my MM to the terminals, and promptly BLEW another P&A fuse.......
You sir, get the runner up prize for jarring my brain into trying another test....
Thanks All!
My EVOs sure were less complicated, but, nowhere near as fun as this Road King!
