se street cannons vs. rinehart
Anybody switched from street cannons to 4 inch rinehart slip ons? I have had my street cannons on for about two years. Like the sound but I want a little louder note. Cat still in headpipe. When funds allow will change the headpipe. My question is will it be a noticeable difference in volume between the two pipes or about the same?
I had the Rinehart 4" slipons on my Street Glide. They sounded OK, but not that loud.
When I replaced the factory head pipe with V&H Power Duals, the sound really changed. Much louder!
I had Street Cannons on my 2014 Limited with the stock header, cat in place. They sounded good but I knew at some point I wanted to remove the cat to get rid of the extreme heat it puts off. I switched to an S&S Power Tune Duals header and kept the Cannons. The Cannons sounded awful with the cat-less header. I swapped them out for 4" Rineharts and I have never been happier. There are several on the forum with similar experiences and the same opinion of Cannons on a cat-less header. p51bombay is one of those members. Maybe he will chime in here with his experience. If not, you would do yourself well to private message him.
In my opinion the 4" Rineharts are best all around for sound. Not too loud but you get noticed when you want. I have the 4" MGS Custom Bike slip on and can be pretty loud when hammering on it but good compromise around town. Maybe Rineharts, R.C. Components or V&H Hi Outputs in the future. Just not sure yet.
I had the SE street cannons on my 15 FLHR and was not impressed at all. They got very minimal use before I went to the RH slip ons. The sound to me, was an improvement. A couple weeks back, I added my tuner and the VH power duals and the sound to me, is much better. Good low note, not obnoxious when your headed down the highway at 65 or even 85.
So with all said - the stock pipe is currently off to make some other changes and I will be drilling/scraping it out this time (got small USB borescope camera to check progress.......I pooh pooh'd this method for a long time until I saw someone's photos afterwards and it was as clean or cleaner than mine that I spent 2 hours grinding on so I'm gonna have a go at it.
As far as the SC sound goes - I've seen reports of two methods to cure this issue. It seems the problem lies with the long end caps - there was a user who gutted the pipe, found the sound sucked and to test his theory.......simply removed the end caps and the good sound returned so he welded on some 2" "extensions" to the mounting plate (where the tips attach to) which is very similar to what HD does with the stock CVO slip ons) Problem solved.
Another user experimented with taking the baffles out and wrapping the core and I think putting the stock wrap back on over top of that(the stock wrap fits loosely to the core - sort of like wearing a rubber so big it doesn't touch your ding-a-ling) - and again........problem solved.
Coincidentally, about this time.........HD releases these new "short" end caps which would likely take car of the problem also. Moral of the story, if you buy or bought SC's and take the cat out - don't give up right away - they are well made (by V&H's) good looking pipes with an emissions stamp if that's important to you.
Just to back up what I said - right after I posted this I see a post on the Facebook HD Touring group with Street Cannons and a VH Dresser Duals so I go have a look thinking they will sound bad but NOOOOOOoooo, the don't sound bad. In fact they sould extremely good and when the camera gets moved........sure enough - he's go the short end caps on there and they sound every bit as good as a set of Monster Rounds.
Turn up the sound folks:
