2014/2015 Primary cover gasket/seal ??
Old 10-11-2015, 01:12 PM
harley0711's Avatar
harley0711
harley0711 is offline
Default 2014/2015 Primary cover gasket/seal ??
getting ready to change out primary fluids - parts book shows 17369-06 Gasket Service Kit.. looks to be small rubber seal/gasket?? On my 04 HD had changed to a large Flat gasket - covers the entire area?? have they changed Back??? I remember on my 2000 - that tiny seal/gasket on the primary was a PIA
today is Sunday - getting ready to place order the Boardtracker HD
Old 10-11-2015, 01:16 PM
jaxdwg's Avatar
jaxdwg
jaxdwg is offline
My gasket set came with the gasket. I pulled out the o-ring and used the gasket without a leak. So I wouldn't worry about it, either/or. Just make sure your surfaces are clean and dry.
Old 10-11-2015, 01:30 PM
ROCKOUT Rocker Products
ROCKOUT Rocker Products is offline
Sponsor
Received 1,628 Likes on 1,176 Posts
My '15 Limited Low uses the rubber o-ring. Have used it over & over with no problems.
__________________
NO, they DON'T all do that!
Also on amazon.com...
JMC22's Avatar
JMC22
JMC22 is offline
On the stock derby cover you can run either/or - it comes stock with the o-ring but you can run the flat gasket cover.........
Old 10-11-2015, 02:42 PM
harley0711's Avatar
harley0711
Thanks Guys, appreciate it
Old 10-11-2015, 03:56 PM
WolfDog's Avatar
WolfDog
WolfDog is offline
Default Re-use
Re-use the primary gasket.
I have 25k on mine. It's not going the leak unless you tear it.
Old 10-12-2015, 12:24 PM
the warden's Avatar
the warden
the warden is offline
+1. I have had my derby cover off more times than I can count. Always careful with the rubber gasket and have never had to replace it.
Beppe
10-19-2017 03:49 PM
emperor wurm
11-15-2011 04:10 PM
OkieRoadWarrior66
07-25-2010 06:28 PM
urleycay
04-24-2010 04:08 PM
Nautilus
EVO
13
04-07-2010 01:41 PM
Quick Reply: 2014/2015 Primary cover gasket/seal ??
