MPG Open trailers VS enclosed V nose
I am looking to get a single bike trailer for times when I just can't ride due to Back problems, time or weather. I would think that a light flat single bike trailer would get better MPG then a box type trailer even with the v nose. I was at the trailer dealership and the salesman is telling me the the difference is very small due to the v nose. I think he's full of sh*t but would like to hear from others. I know the pros and cons for both, just want to know about gas MPG. Tow vehicle is a Toyota 6 cyl. van.
Thanks JIM
Thanks JIM
Thanks JIM
Thanks JIM
Received 2,524 Likes
you really want:
2 axles
brakes
I have seen more single axle trailers rolled at the side of the road than I can count.
the most recent and spectacular was an open trailer with a single axle, no brakes.
2 roadkings strapped in, side by each
the right tire tire blew, the trailer dropped down on the right side and started pulling.
the driver braked hard
the trailer has no brakes and tried to pass the suv on the right.
it jerked and one of the roadkings went over the side...it;s straps pulling the other road king and the trailer on top.
mpg should be the least of your concerns, check the rating of you van- what can it pull, how much tongue weight
an open trailer will have alot of drag and may offer more resistance than an enclosed trailer - a V front will do better, but see if that is wasted space
mike
2 axles
brakes
mike
I had a Continental single bike trailer. Did what it needed to do but tires were too small, 10" I think. Rolling a vehicle down the highway at 70 MPH those small tires are spinning a whole lot faster, hence very fast tire wear. On a trip about 800 miles I nearly had a tire blow but caught it just in time. I sold the trailer.
Ask yourself how often you will use a trailer. If fairly often buy whatever suits your needs. If just an occasional trip to haul your bike I would rent a U-Haul. That is my plan but I don't tow my bike as much as I used to with change of work travel cut to nil.
i tow a tandem axle vnose (7*12) with a 5.7 tundra. My MPG is about 9 while towing. Without the trailer I avg 15. I dont think there is much difference Vnose or bull nose. You are pulling a box and that is a lot of wind resistance.
I do like my bike inside for protection.
Last edited by luc.who; 11-01-2015 at 04:16 PM. Reason: added the wind resistance comment.
