2003 road king gas tank capacity
I have a 2003 Road King I picked up last November with the original tires on it. I am 70 and this is my first Harley. I get about 100 miles before I have to switch to reserve. My question is: If I start out with a full tank and leave it on reserve, will the reserve run down and allow me to switch back to full tank and have it act as a 3 gallon reserve?
I want to get the bike ready for winter and would like to run down the untreated seafoam reserve.
I know, I should have had a Harley a long time ago.
Tires have been changed. I want to have a full tank of gas with seafoam for winter. If the reserve tank is full and I put 6 oz of seafoam and fill the tank it will all go in the non reserve side. I would like to drain the reserve and still have enough gas in the tank to make it to a fill up. Does that make sense?
Received 1,934 Likes
In the spring, when conditions permit you to ride, start your bike and run it up to full operating temp before shutting it down again. Thats it.
Also, owing to the size of the tank and the internal baffling, fill ups were tricky for me at first. If you just put the nozzle in and fill till the pumps automatically stop, you're nowhere near full. Carefully top off and lightly wiggle your handlebars, to get the air up past the baffling. You can probably get an extra 1/2 gal in. You're getting better than 25 mpg on that bike !!
ALL 2003 Road Kings have a 5.0 gal fuel tank.
Since you have a petcock you obviously have a FLHR (carb model) which has 1.0 gal "reserve" capacity and adding any fuel or additive mixes with the entire capacity of the tank.
I also have a FLHRI model.
Be sure to have the cam chain adjusters checked at 20,000 miles (or so) and replace as necessary and you'll get many years of service out of that bike.
And definitely get yourself some new rubber too. Enjoy!
As previously mentioned, it's one tank. There are 2 hoses off the bottom. One part way up (at about the 1 gallon point) and the other right at the bottom. Al he fuel switch does is select which tank port it draws from.
If you forget to switch back after you fill the bike you'll be walking when you think you've hit reserve. Don't ask me how I know
