Horn question
Old 11-10-2015, 01:07 PM
lc1484's Avatar
lc1484
lc1484 is offline
6th Gear
Default Horn question
I am replacing my horn to a Wolo on my 1992 FLHS. there are 2 wires. 1 black and 1 green. Which wire is ground and which is hot?
Thanks
Old 11-10-2015, 01:37 PM
SlowRain's Avatar
SlowRain
SlowRain is offline
Traditionally black is the color used for the ground. Now having said that...I would get your multimeter...or borrow one from a friend...and check for sure.
Old 11-10-2015, 02:19 PM
TcHunter's Avatar
TcHunter
TcHunter is offline
I always thought green, was ground.
Old 11-10-2015, 02:56 PM
Brewmany's Avatar
Brewmany
Brewmany is offline
I'd second the idea to put a meter on and verify it. If it's factory installed or was put in by someone following standards, black is usually negative. In your case I'd guess that the black is negative and the green is positive.
Easy enough to check with a multi meter.
Old 11-10-2015, 02:57 PM
Brewmany's Avatar
Brewmany
Brewmany is offline
In household wiring. Green or bare copper could be ground. White or grey is usually neutral, and other colors (red, black) are hot.
in 12v D/C (cars, motorcycles, boats,) black is usually negative and red positive.
Old 11-10-2015, 02:58 PM
mkguitar's Avatar
mkguitar
mkguitar is offline
harley uses black for ground---but as above check with a meter.
Mike
Old 11-10-2015, 05:58 PM
TcHunter's Avatar
TcHunter
TcHunter is offline
Thanks Brewmany, I don't know what I was thinking.
rquest
03-18-2017 02:21 PM
Ratmobile
04-28-2014 06:18 PM
HDRider2002
06-30-2009 10:21 AM
freebyrd
09-10-2008 10:57 PM
RMBob
08-13-2006 09:13 PM
Quick Reply: Horn question
