voltage regulator uncovered
To have a finer view of the components, could you scan both circuit boards including their rear side ? You can cut away the bulky connectors to lay the regulator circuit as flat as possible.
The 40Amp Maxi-Fuse protects the regulator from being fried by the battery in the case of a short circuit on it's output side. This could be interesting to understand what can be done if either the Maxi-Fuse or the regulator dies without using the cell phone
if your voltage regulator fries, the stock vr is 74505-09A and retails for $221. you can buy the chrome replacement, 74622-09 which retails for $179. so buying the chrome one will save you almost $50.....
Top
Undeside of top
Top of bottom piece
Bottom
Vernal, thank you for sharing sharper pictures.
I spotted at least 20 surface mount transistors (Q1>>Q20) on the "Gecco" board held by pins (PIN1>>PIN11), so we can forget about repairing this thing
When you search the printed board reference RTF D-1 94V-0 you end up on a Chinese web page ...
I guess the best thing to do if this component fails is to disconnect it completely and run from the battery through the 40A Maxi-Fuse.
Thanks for posting that,it shows it was overheated melting electrical components in the process.
Thats why i never install a chrome cover for looks on the v-reg & keep it clean of dirt at all times to ensure it gets full airflow for max cooling at all times .
And thats not taking into account the front wheel & fender that are already blocking x-amount of airflow from getting to / cooling the volt reg so covering it with chrome cover for looks and or not keeping i clean of dirt can reduce cooling even more with is a RCP for the v-reg to overheat & fail prematurely.
scott
scott
scott
scott
It's interesting you brought up the (over)heating of the VR. I went to a dealership to purchase a chrome VR. The parts guy told me that several customers have mentioned that their chrome VRs were overheating and failing. I asked him if he was aware of similar problems with the chrome covers and he said no.
I took his advice and bought a chrome VR cover. I have had it for a couple of years now without a problem.
scott
scott
