SERT vs SERT Pro
You can use the SEPST and tune with your smartphone?
All 3 I mentioned technically use a laptop, All 3 are technically removable.
All 3 let you do more than the SEPST...
All 3 allow you speedo calibration, which none of the SE products allow.
The FP3 allows you real-time data gathering with your smartphone.
The PV2 allows you real-time data gathering that you can see on your handlebars... Yes, auto tune while watching the cells, simple to do on back roads.
Next tuner I get will be the Power Vision. It is an all-in-one design that will eliminate the extra cost and strapping additional hardware precariously to the handle bars.
Technically, the SEPST will mess with your warranty as much as the PV2, or TTS or FP3.
Let me ask you a question, or rather ask yourself this question, as I already know the answer...
How can making the engine run correctly affect the warranty?
If you hop the top end way up, go with some extreme shave and polish job with huge cams and achieve super high compression and you bust your crank, it's not going to be covered.
Fattening the mix up a bit, and getting your VE tables in line isn't going to do that. If your stereo craps, it's still under warranty.
If you tune it way too lean, and burn a piston, no, it won't be covered.
Thanks all for the info.
They do more, for considerably less money. There is NOTHING the SE products do better than the other 3...
EXCEPT get deeper in your wallet.
If you're happy spending the long dollar for the orange box, power to you, it's your wallet, I couldn't care less.
Personally, I LIKE the ability to correct the speedo, I calibrated with an external GPS, and was out 5%. Now it is dead on.
I am an intelligent human being, I don't need my machine lying to me to keep me legal, I want to know the actual speed I am running.
My speedometer, when crossed with an external GPS unit, is dead nut.
I also like to be able to change tunes on the road. I can store 6 tunes on my PV2, and if I decide to use a different one, say for fuel savings, or for more aggressive twisties, it takes less than a minute.
Bring the screen up, choose tune, load tune, shut bike off, turn bike on, roll.
3 Week old Road Glide Ultra. I went with the FP3 and couldn't be happier. Total control and especially pleased with the "Throttle Progressivity" feature. Like SafetyMan, I appreciate the ability to change maps in a flash for my desired riding conditions. The FP3 is small and lightweight and you can leave it plugged in for added real-time features and control.
I wanted you to elaborate on what it can do beyond the SEPST. The "Throttle Progressiveness" is in the SEPST as well.
As for tuning on the road in under a minute is cool. Do you use that feature a lot?
The speedo calibration is cool as well. I do not think there is a way to do that with the SEPST. Never would have guessed they were off by 5% which is odd to me. You think by now HD would have the speedo calibration corrected.
Anyway always good to know about as many of the units out there to tune.
I just like my SEPST as that is all I have ever used.
Not to question your intelligence but the title of the thread is SERT vs SERT Pro .
Not bashing any other tuner out there. Just uneducated in them. As for money... If we wanted to SAVE money we would not own a HD motorcycle.
