wobble - death??
this fall away spec/test is a crock. hahaha. if u dont want headshake then tighten up your steering stem to the point were you have to actually push the handlebars to make them hit the stops. this way you are using your bearings and tightness as a steering dampener. trust me. your not gonna hurt modern bearings my tightening down on them. i do this and i have no headshake. been doing this on motocross bikes for years and the beating they take is much more than a harley gets even a 900 lb ultra. i always laugh when i see this test on you tube.
Received 47,780 Likes
I laugh everytime I read "don't take your hands off the bars". Any properly set up bike should run true down the road without hands on the bars. Period. I have rode my Softail for miles and miles without my hands on the bars. I use my knees as rudders to steer through light curves and bends. My Electra will ride the same way, but takes more weight shift side to side to get it to turn. Even my Buell will run true down the road with no hands. The basic fundamental of how a motorcycle works is, the gyroscopic momentum of the wheels helps keep the bike upright and continuing in a straight line. You ever see a super bike race? A guy will get into a huge speed wobble, to the point the bike throws him off. The bike then corrects itself and continues straight, without a rider, till it hits a wall or barrier.
It's the same thing in the Jeep forums. "I lifted my Jeep, now I have death wobble." First response, "you need a steering damper". No, a correctly set up steering system works the way it should. It returns itself to running true and straight when no input to the steering is there.
OP, tire, tire pressure, wheel bearings, head bearings, if you have spoked wheels check them and have them trued, like everyone else has said. Unless you somehow changed the steering geometry, ie; lowered the rear but not the front, lowered the front but not the rear, put a huge front wheel and tire on without changing the rake, etc. Good luck tracking it down.
I should note that the only time that I encountered the "wobble" in the front end ( not be confused with the notorious HD Death Wobble ... tracking in sweepers ) was during sudden deceleration while the bars were held very loosely. I never noticed it "at speed" . Again snugging the neck bearings resolved the problem.
