Tuner for stock Road King??
My bike came used with stage 1 AC and gutted slipons. Ran like crap so I put stock mufflers on. I put a Fuelmoto PC3 on and it helped noticably. A huge earth shaking improvement, no, but enough I could tell. The lean surge was gone, it ran a little cooler and the throttle response was smoother and I could tell I had more power.
When I finally put a good set of slipons on then the tuner really opened her up.
A tuner will help stock. You have slipons so it will help even more. You can also get a k&N filter to fit the stock AC housing which will help even more.
If I were to ever hop up my new bike (which I am not), I'd go this route, (this might be a llittle more than your budget however). With the stellar performance of the Powervision and numerous maps at your fingertips from proven combo's that Fuel Moto has personally created, to me, you can't go wrong. With the proper canned map from them, you'll be pushing 102tq/84hp.
Received 2,524 Likes
Just curious why you're not planning to hop up your new bike? Especially since you have a method you're completely confident about. I'm only asking because I've modded my past rides, but in this case I'm leaning more towards stock...although I'm already faltering as I look at slip-on deals on Fuel Moto's site....then the ceramic header....then a tuner...
Hoping to get some good feedback here. I have a 2015 FLHR and it's stock as far as performance, although I did install some CFR Slip-ons. My question is would I benefit from purchasing a tuner? Would I notice a difference in power or sound? This is my first Harley so take it easy on me, haha. Looking to up performance but only have about a $400 budget for now. Thank you in advance for the advice..
Received 3,940 Likes
A completely stock bike will benefit from a tuner, no matter what anyone says. There's more to tuning than peak numbers, and if they're all you care about, you probably shouldn't have bought a Harley.
I know this because I've run a tuner on every Harley I've owned, and I've seen my share of dyno charts. I have a completely stock bike at the moment and I'm running a PV with a FM tune in it. Guess what? It runs much better than it did when it was stock. Idles better, accelerates smoother, gets better mileage, and is more fun to ride.
There is a lot more to tuning than just "adding more fuel".
Here is a thread with an overview of the popular tuners.
https://www.hdforums.com/forum/ignit...uning-etc.html
For your budget either the FL-ViED-10, or better yet the FP3 will work. If you can save up a bit more, and want the king of the hill in tuners, then the Power Vision.
Either of the three above will be better than the stock tune or an HD download.
Ride it like it is, save some money and read the forums. I would go for the Power Vision. Down the road no matter what you decide to do to the bike it will give you the most flexibility to properly tune it. Slipons, head pipe with no cat, and an intake with a tune will give you a little more power, cooler and better running bike. If you are happy with the sound of your pipes now none of the other stuff will change it much.
Next cheap power boost will come from cams. After that save more money...
BTW, sweet looking bike.
