Ape hangers for 2012 streetglide
I went with the Harley 12" Batwing Mini Apes and all the related Harley cables. I spent weeks trying to figure out if I needed to spend the extra money on extended cables, trying to find cheaper alternatives, something used, etc. Finally, my bud let me ride his Ultra with the same set up and that sealed the deal for me. It was by far the best set up out of all the other bars I have checked out (whether it be at the shows or on other peoples bikes). I found that the Harley bars felt the best because they have limited pull back (1.5 or 1.75" I believe) and they are actually 12 inches (not 11.5 or 13 like the other manufacturers 12" bars). I also got a ton of peace of mind knowing that all the parts are proven/tested, and under a real warranty. Hope that helps.
If you have the funds, definitely go with pre-wired. Hill Country Customs has lots of great bars with great quality and they sell them pre-wired and with all the controls too. It was a lot of work and aggravation wiring my bars and the stock wires will just barely make it through a 14" set with enough left sticking out to connect the extensions. With a 16" or higher you will have to pre-connect the extensions and then its a real pain to get them through the small hole and inside and through the bars.
I see there are many opinions on bar height and brands.I was stronly considering Hillcountrycustomer but really am affraid to due to the negative reveiws even from my local HD dealer. They by far have the best deal and even chrome controls with there package.Really affraid ordering something you can't see
