Ape hangers for 2012 streetglide
I also have a 2012 SG.
last month, I had a 12" Yaffee Bagger bars installed. Great upgrade! I have better control of the bike and its more comfortable than the stock bar. I'm 5'11 and it's a good size and I have the bar pulled back a bit for more comfort. Maybe out of vanity, I wonder what 14" feels like but I'm happy.
I did 16" KST Kustoms Mayhem bars. I'm 6' but have a long torso and shorter legs so the 16's are spot on for me, it's one of the best upgrades I've done. Helped with my shoulder pain. Did the install myself. If I did it again I'd make my own wire extensions vs buying a kit. I'd buy a spool of good wire and some heat shrink. I'm pretty handy with a soldering iron so that helps. A third hand (found at harbor freight) is good for holding the wire ends while soldering.
I just did the 12" Yaffe's which are like everyone elses 14's. I am very happy with them. I did not buy wire extensions. I bought a roll of wire and soldiered the wires. I cut the original harness in a staggered pattern and used the exact same sixe extension. It made the process easy plus have to keep the bundle small because they have to go through the bars.
It's the extended clutch cable that will kick you butt Everything else was fairly straight forward.
