Does Newer CVO Exhaust Fit 2010
The 09 is a different story. Header is the same pipes the same however the 09 had the large 02 sensor located right at the exhaust port. kind of a pain to plug them and weld in small ones in proper location.
Mine is a '10, so it has both the CA cat and the smaller O2 sensor.
I'm actually looking to REDUCE the exhaust dB levels. Yes, heresy I know, but on the long rides it would be nice to just hear the exhaust note without the ears bitching. On some earlier threads some folks seem to like the CVO mufflers for that reason.
I had the same experience with the cvo mufflers. With a Fuel Moto head pipe, cvo mufflers were actually quieter than the stock mufflers. On mine the stock mufflers actually perform better, but not by much. There is a ton of packing in the cvo also. I cut apart the cvo baffle, the changes in pipe size are huge. Inlet is like 2" swells in the center, then a 1 1/4" perforated pipe comes out into the baffle to restrict the flow then swells to the 1 3/4 exit pipe. I have the 2" Fullsac baffles coming also.
