Handlebar Bushing Question
OK, going to install khrome werks 14" bagger apes. Thinking of replacing the bushings while I am at it. I currently have 12" Wild Ones on there. Nothing to indicate I need new bushings other than what I have read on the forum.
Here is my question, I have read somewhere that the HD and other poly bushings are too tall or something. Top clamp doesn't fit right? I think Wild One has reduced height bushings so the top clamp is flush?? Is the only clearance issue with Wild One bars or with Khrome Werks as well?
Not sure if any of that makes sense but if I need new bushings I want to get the right ones and I cant find the threads on it.
Thanks all.
Thanks all.
Not to hijack but ,What wild one bushings are being used ? Their website says their touring bushings will not fit the 14+ years .
Op if you already have poly bushings no need to change them out, but are suggested. I have the alloy art riser bushings , they were taller than stock I had to get longer bolts to make them work, I did not have any issues with the top clamp lining up or not fitting.
Thanks all.
Thanks all.
I would just go ahead and replace the bushings since you have them all taken apart. I bought the Arlen Ness ones on EBAY, Brand New for like $30-40.
It was a simple swap out and they fit perfectly. As others may note, the taller the handlebars the more leverage you are putting on that fulcrum point, thus a "Brand New & Stiffer" bushing is always going to help!
Good Luck. Ride Safe and Ride Often. Rubber Side Down. Over and Out.
