2002 Road King exhaust manifold torque and sequence
Hi, new user from Atlanta. I have a 2002 Road King Classic and am pretty sure I developed an exhaust leak last Saturday. I have a HD factory service manual on order but doubt it will be here before I am supposed to go on a ride this Sunday. Can someone please share the torque specs and tightening sequence for the front and rear exhaust manifold nuts? I know they are tightened in a couple of steps and go top to bottom and vice-versa but not sure what those values are for the Touring models.
Thanks in advance!
Tommy
Thanks in advance!
Tommy
use antiseize paste on the thread- this goes alot looser than you think INCH pounds...some guys bust studs
a. Tighten the bottom nut of the rear cylinder head
exhaust flange to 9-18 in-lbs (1-2 Nm). Tighten the
top nut to 100-120 in-lbs (11.3-13.6 Nm). Final tighten
the bottom nut to 100-120 in-lbs (11.3-13.6 Nm).
b. Tighten the top nut of the front cylinder head exhaust
flange to 9-18 in-lbs (1-2 Nm). Tighten the bottom
the top nut to 100-120 in-lbs (11.3-13.6 Nm).
