upgraded to the 110 stage V kit w/ PCV autotune on my 2010 Streetglide. Added the automatic compression release kit as well. Is there any way to download the compression release info without going to the dealer?
Ground one side of the ACR and feed power from the starter solenoid hot wire. ACR will work as long as the start button is pressed and starter engaged or just use the the low current going to the starter solenoid from the start switch and use it to power the solenoid (ACR relay). The relay coils don't take that many amps.
also where is the option to turn them on with the power vision should you run the factory harness?
Here on page 4, plus the digital technician that the dealer has can enable them. I am not a big fan of cutting or splicing HD wiring in any way but on the plus side when something goes wrong, a guy will know where to look, LOL:http://www.powercommander.com/downlo...icktune.01.pdf
