Still a bit confused about torx.......
Do you need to get a torx bit set (the kind that goes on a screw driver handle, or a torx bit onsockets setthat you use on a 1/4 or 3/8 ratchet? Also....the torx screws on a harley are standard torx.??, not plus or tamper proof ( what ever that means?) Correct.. If you use the torx on the end ofscrew driver type, how do you torque those to specs? Don't you have to use the socket type torx with torgue wrench?
Thanks inadvance for your help in clearing up my stupidity.
RE: Still a bit confused about torx.......
Harley does NOT use "tamper proof" torx screws, so no worries there. I have a set of 1/4 (smaller bits), and 3/8 drive bits. You can get a screwdriver handle with a 1/4" drive on it to start the screws, and then put the bit on a QUALITY torque wrench (NOT a beam wrench, but digital or click from a GOOD company) for the final tightening.
jimmy z
04-15-2019 08:46 AM
baka1969
05-20-2012 12:16 AM
