Aquatic AV radio review
#31
#32
#33
#34
'fooz
#35
#36
#37
No, my guess is there is a AVC setting that needs to be adjusted. Next time I ride, I'll play with mine and see if there is an automatic volume control.
#39
I got the ****hs model came out in december paid 599. So far so good. heres what ive notice so far.
I like the way they dummied it down in some ways,and I mean that in a good way cause its made for a bike.Clock has 2 settings,big or tiny if time is important. It starts on a delay to give me time to start the bike so i can just leave it on all the time and just turn volume down or mute. Changeing folders on usb can be done but not a one button operation, you have to get use to pushing a button and a couple more step with out looking at it similiar with mode change(learning curve,not biker friendly much there).
It has not had even one gliche or hicup even if you run over a truck tire.But here comes the problem ive narrowed down to my controls, seems if the get them a little wet the volume on the handle bars stops working, if i get caught in a downpore or it sites out in the rain the hand controls go crazy to the point where the radio controls dont even work right. and one thing its done like the op mentioned is i hit the mode button on handle bars and volume starts going up, yipes!! have to pull the face plate off while riding and snap it back on to stop it!! but only when hand controls are soked..I got some non harding clear silicone that im going to use on the control switch this winter to see if that helps and until then im just going to live around that issiu. dry out works flawless. if that doesnt work to my likeing Ive thought of makeing a quick disconnect for the handle bar controls.......by passing the issue would be my next guess?
#40
