Transmission curiousity
Does anyone know if the 6 speed tranny out a 2010 FLHX 98 cu.in. would fit a 2006 FLHX 96 cu.in? I have the option to buy just the tranny from a local or the whole package motor and tranny. I have some work into my 96 and would hate to toss it away and start over. Plus I don't know if the harness is different between the 2 either. Not to mention the $$$ difference.
Thanks
Thanks
I assume that the 2010 is a 96 and the 2006 is a 98?
Doesn't really matter though. As far as I know, the trans won't bolt up to your 2006 and it would take some work to get the complete powertrain into your bike. You'd also be giving up a bunch of performance going from your built engine to a stock one.
It's neither here nor there though because we both agree that it won't fit
Best way to have 6 gears is a Baker DD6. That's on my wish list (after suspension, engine, etc, lol)
Here's what they're talking about why it won't fit. Look at the front of the older transmission case where the #15 is. Note that there are no oil passages between the two. Instead there are oil lines from the engine into the transmission case.
Now look at the newer trans case just above the 11-15 numbers are. Those oil passages are now a part of the A motor/trans cases with a gasket in between.
