Transmission Sprocket removal
crap.....indeed, changing the seals is the reason i am trying to pull the sprocket. I think i will try cutting off the race and going to the Baker bearing that replaces the current inner primary bearing and race...anybody know the part number for this? Baker's website doesn't list it for bikes newer than 2007.
sn95bullitt - how did you get the sprocket nut off? I've been trying for two days now, no success so far. I have the special socket, been trying with a 4 ft pipe slipped over a 1/2 breaker bar. i did apply some heat, but maybe not enough yet.
Thanks!
crap.....indeed, changing the seals is the reason i am trying to pull the sprocket. I think i will try cutting off the race and going to the Baker bearing that replaces the current inner primary bearing and race...anybody know the part number for this? Baker's website doesn't list it for bikes newer than 2007. sn95bullitt - how did you get the sprocket nut off? I've been trying for two days now, no success so far. I have the special socket, been trying with a 4 ft pipe slipped over a 1/2 breaker bar. i did apply some heat, but maybe not enough yet. Thanks!
For the race, if you don't have a puller, cut almost all the way through it then hit it with a punch. Shouldn't take much to get it to crack open so you can slide it off.
For the trans sprocket nut, if you can't break it with brute force, drill a hole into the nut and use a punch on it as well. I have found that holding pressure against the pry bar and giving a good hard yank breaks that nut loose easier than a constant hard tug.
Thanks!
Thanks!
Originally Posted by Gordon65
thanks...do you recall what your gun is rated for torque? I can get my hands on an impact wrench rated at 450...not sure that is enough though...
