rear cylinder does not fire
Old 01-24-2016, 07:09 PM
Hilowaiian's Avatar
Hilowaiian
Hilowaiian is offline
Default rear cylinder does not fire
09 SG
sat for two years
new Battery
Plugs
oil change
Rear cylinder does not fire. Plug wire has spark, swapped plugs same results
Any help would be appreciated
Old 01-24-2016, 07:20 PM
vbx07's Avatar
vbx07
vbx07 is offline
Originally Posted by Hilowaiian
09 SG
sat for two years
new Battery
Plugs
oil change
Fuel injector?
Old 01-24-2016, 07:21 PM
Bubba Zanetti's Avatar
Bubba Zanetti
Bubba Zanetti is offline
Received 13,138 Likes on 5,590 Posts
Any engine codes? If I remember the newer bikes have a "safety mode" or "limp mode" or something like that that will shut the rear cylinder off when the bike gets too hot. Maybe it malfunctioned? IDK, just throwing some stuff out there
TSheff's Avatar
TSheff
TSheff is offline
Received 3,340 Likes on 1,548 Posts
Plug wire sparks - it has fire.
Are you stating it won't start or run?
Just a suggestion - get some starter fluid and squirt it on the intake manifold (AT the REAR CYLINDER) while trying to start it and see what happens.
Old 01-24-2016, 07:26 PM
harleycharlie1992's Avatar
harleycharlie1992
harleycharlie1992 is offline
Unofficial HDF Chaplain
Received 14,574 Likes on 4,610 Posts
if head temp sensor is bad it will read too hot and shut off rear injector.
Old 01-24-2016, 07:30 PM
TSheff's Avatar
TSheff
TSheff is offline
Shoudn't that throw a code? Of course someone asked that, don't know if the OP has pulled codes or knows how.
You are correct - no fuel. Injector or intake seal leak.
Old 01-24-2016, 07:31 PM
bigdumbnoitall00's Avatar
bigdumbnoitall00
bigdumbnoitall00 is offline
pins on the injector plug in fretting?
Old 01-24-2016, 07:37 PM
harleycharlie1992
Yes it should have a code, but We aren't there!! If it has a bad enough intake leak to shut off the rear cylinder, thats big!!! And you also wind up with an adaptation code. A misfire, sure but shutting off the injector? And we don't know if the cylinder is completely shut off. It may be a rear cylinder misfire, that the ecu has shut the injector off. these guys give so little info! need some live data.
Old 01-24-2016, 07:45 PM
TSheff's Avatar
TSheff
TSheff is offline
Only reason I threw in the seal is I bought one last year (granted an EVO) but I did all the troubleshooting on sight I could. Only 10 miles from home so I decided to ride it on 1 cylinder. Once I got on a straight run and rolled the throttle she started picking up then cutting back off as I slowed. Got home let her cool shot the starter fluid to the intake seal as I cranked her and she ran well. $3K + $12 parts became $6K.
Air - Spark - Fuel, don't get much easier.
Old 01-24-2016, 08:16 PM
harleycharlie1992
nice buy!!
"compression", spark, fuel.
Quick Reply: rear cylinder does not fire
