Turn signal module 69462-06c vs 69461-06d
Old 01-29-2016, 10:03 AM
Sturgis67's Avatar
Sturgis67
Sturgis67 is offline
Default Turn signal module 69462-06c vs 69461-06d
I have a chance to get a 69462-06c module at a great price. Other than the lenses being different (which I don't need anyway) is the wiring harness the same as the 69461-06d which is specified on the HD website for my 2013 FLHTCU?
Thanks!
Old 01-29-2016, 10:08 AM
Uncle Larry's Avatar
Uncle Larry
Uncle Larry is offline
Received 47,791 Likes on 18,561 Posts
http://www.harley-davidson.com/app-c...ts/-J03968.PDF
Generally when the last letter of the part number is different ( later ) ... "c" as opposed to "b" ... "d" as opposed to "c" it indicates a "running change" ( improvement ) in the part and they are compatible
Old 01-29-2016, 10:40 AM
Sturgis67's Avatar
Sturgis67
That's what I thought. I also figured that the 61 vs 62, in the part number, was specific to the bullet lenses vs flat lenses. Agree? My thoughts are that it should work fine.
Old 01-29-2016, 10:45 AM
Uncle Larry
Woops ... Didn't catch the 61 vs 62 .... Gettin' too old I guess :>(
Old 01-29-2016, 11:52 AM
Joe12RK's Avatar
Joe12RK
Joe12RK is offline
Received 1,412 Likes on 881 Posts
Looks like it will work. Here's the fitment info from the HD website:
69462-06
Fits '02-'03 XL, '02-later Dyna® (except FXDXT and '09-later FXDB and FXDWG) and '02-later Softail® (except FXS, FXSB, FXSBSE, FXSTD/I) models with stock bullet-style turn signals. (NOTE: Not intended for use on '04-later FLHX, FLHRS, FLTR or FLHTCSE models, '05-later FLSTN models or models equipped with Bullet Turn Signal Bar Kit P/N 68615-04 or 68617-04. If installed on these models, the system will function properly but will not meet the DOT minimum separation requirements for a red tail light to red turn signal.)
69461-06d
Fits '96-later Softail® and '97-'08 Touring models (except FLHX) equipped with Original Equipment flat lens style turn signals. Also fits '09-'13 FLHR, FLHRC, FLHTC, FLHTCU and FLHTK models. (Does not fit with Narrow Chrome Directional Bar P/N 68611-98.)
Old 01-29-2016, 11:58 AM
Sturgis67's Avatar
Sturgis67
Yup, read that too. Thanks for the input gentle mans! You have both reinforced my initial thoughts.
tosaman
07-29-2018 08:49 PM
cpmman
07-16-2016 10:34 AM
larsfum
EVO
01-12-2011 11:02 AM
George D
01-16-2009 08:00 AM
ausfxdwg
06-19-2006 07:40 AM
Quick Reply: Turn signal module 69462-06c vs 69461-06d
