Is anyone running the Drago's Bikeworks 565 or 580 cams in their bagger? I'm thinking about a upgrade and looking for input. Thanks.
Put the 580's in my brothers Limited (103) last spring. Also put Dragos 2:1 exhaust, Thundermaxx tuner, Zippers air cleaner, and S&S pushrods and lifters.
End result was 97hp and 108.5 tq. No more top end rattle, bike runs strong.
How do you like them? Is the motor stock otherwise?
My bike is a 110'' CVO King. Current mods 580 cams, Dragula 2 exhaust, SE high flow air cleaner, Se race tuner, new lifters and push rods. Preliminary dyno results are 105Hp and 120TQ. Haven't had a chance to take it for a rip yet.
[QUOTE=cpunchedglider;14834572]Put the 580's in my brothers Limited (103) last spring. Also put Dragos 2:1 exhaust, Thundermaxx tuner, Zippers air cleaner, and S&S pushrods and lifters.
End result was 97hp and 108.5 tq. No more top end rattle, bike runs strong.[/QUOTE
Nice numbers. How does that exhaust sound? Do you have a dyno sheet you can post?
No dyno sheet with me, gave it to my brother when dropped his bike back off with him. I also run a Dragos 2:1 (my motor is a Dragos built 107). Pipe(s) sound great at idle and on the throttle, nice and mellow, almost quiet at cruising speeds.
I have the 580 cam and just switched to a fat cat... we'll see how I like the pipe. If I don't I'll be going back to a dragula. It needs to be put back on the dyno, running the autotune pro and powervision.
I like the cam quite a bit.
