Condor Chock, which position do you use ??
When loading a condor your wheel rolls up and over the pivot on the chock. If the chock is too far back the wheel rolls down off the pivot point a lot. Maybe 2" lower. To unload your bike you gotta roll 400+ # up and over the pivot. Ugh. Adjust so the wheel rolls down enough to squeeze tight against the front rest, but no so far down that the wheel rests far below the pivot. The front of my chock is not resting on the floor when bike is loaded. Much easier to get our heavy azz bikes off the wheel chock.
3rd hole is most secure. I use one on my lift table and don't even put a strap on it, when loading bagger. When I load a bike with a 21" wheel I HAVE to put strap on it.
If using on lift table - put a sizzor jack under frame and hand tighten, in case front tire loses air. Bike will fall
