Rocker Box Questions (96ci)
I'm about to remove my rocker boxes for powdercoating and have a few questions. I've read multiple threads and watched a very informative video on YouTube but I still need a little clarification.
Q. As I understand it, I have to find TDC for one cylinder at a time in order to remove the Rocker assembly safely. After I repeat this step for the second cylinder, the first one will be out of alignment again. How do I reinstall the assemblies without damaging anything?
Also, I'm performing the work in my shed. It has plywood walls/floors and gets quite dusty. Other than covering the exposed areas(rockers, primary, cam area, tranny) with a garbage bag and painters tape as soon as I've removed the covers, is there anything else I should be doing to prevent damage from the dust?
I'm still unsure of what to do after going from one cylinder to the other and any damage that may be caused. So I'm just hoping for someone with first-hand experience to chime in and clarify that one part of the process for me.
Thanks again.
The only thing that's important is making sure the cams are on the base circles which is easy to do.
Elevate the rear wheel after you have the rocker cover off.
Turn the rear wheel in 5th or 6th gear (top) until the rocker arms in either the front or rear cylinders are both down. You'll see them move up and down, if you go too far you can move the wheel in the opposite direction. It doesn't matter which one you do first.
Unbolt/remove the rocker assembly and the breather system. Mark which cylinder it came from (front or rear)
Remove lower rocker box and repeat for other cylinder.
Cover everything with plastic and seal with tape until install.
Thanks for the detailed response.
What about the reinstallation? Do I have to get back to TDC when bolting the rocker assembly back or will it just go back together without any fuss?
Forget about the TDC thing brother. As long as the push rods are on base circle of the cams for that cylinder it doesn't matter. You'll see the pushrods (when you re-install) rise and fall. Put the rocker assembly on (after installing the lower rocker box) and evenly cinch down the bolts making sure the pushrods are up in the cups of the rocker arms.
Torque to spec, install breather assembly and move on to the other cylinder. One thing I forgot to mention. Remove the spark plugs before trying to turn the rear wheel, it makes it a whole lot easier. And before you remove the spark plugs, blow compressed air around them first so nothing falls in the cylinders.
