Ok well this is strange ... Turn Signal Bulb
Just for the heck of it you could try to see if your 4-way flashers work. Turn the key on, press and hold both directional switches until the bulbs start flashing, then release the switches and turn off the key. The bulbs should continue to flash. See which element is flashing. To cancel the 4-way flashers, turn the key to on, and press both directional switches again, bulbs should stop flashing, turn key off. This should allow the directional element of the bulb to light and leave the running light element off (no power to it).
Did the tail light and rear turn signals work OK?
You're probably fine checking the fuse like that. On a rare occasion you might miss a blown fuse. I was more fishing to see if you had a Volt/ohm meter. You can buy a meter for $20- $25 dollars that would serve you well working on a problem like this at Walmart, Radio Shack, Sears or Home Depot.
Brake, rear light, rear turn signals all work perfectly. Interesting though that the rear bulbs are 1156 (one filament only).
I'm starting to wonder if someone put 1157's up front by mistake and they should be 1156's up there too.
In the front they are doing the turn and running in the same housing so dual filament bulb. Unless I'm interpreting the print wrong, it shows the blue wire dashed and says Running DOM only and I think that means Domestic as HDI means international.
Well well well ... It's nice to have an easy fix every now and then. Got two new 1157A's and put them in and whaddya know. Work exactly like I'd expect.
It's problems like this though that force me to go in and learn about the bike. Made me go out and order a Clymer Service manual. Made me find the fuse box and checked all of them (btw they don't make the fuse box easy to get to)
I feel smarter regarding my bike and all I did was have to replace two bulbs.
You guys are great on here. I really appreciate the help.
