handle bar woes
handle bar woes
I have a 2010 flhtk. went with 12" kst bars and picked up the magnum shielding wire extension kit from local dealer. I fought and cussed and screamed and could not get the wires through. I damaged the little green connector and bought the CVO throttle from dealer. I sent my bars and wires to a local indy shop to get run through and have the connectors re pinned. Now I'm looking at everything and I think I'm screwed. He cut the correct pins off the NEW CVO throttle sensor and heat shrunk the pins on that fit the green connector and reused it with heat shrink to hold it together. It pulled out with the first slight tug. My question is do I have to buy another new CVO potentiometer and re run the wires? I have some pins that look like they would fit the correct plug. How sensitive to change in wire length is the sensor? Can I cut the wrong stuff off and connect the correct ones. The indy shop I took it to is a owner/operator who went for back surgery the day after I picked up my bars, so taking it back to him for the next few weeks is out of the question. He was a decent guy and seemed knowledgeable, so I don't want to be too much of a dick about getting it all fixed up. But I want my bike back together. I'm sure he would make it right if he physically could. Thanks, pitbull
To answer your question, yes you can cut, replace, and solder whatever length you need to to fix it. Key thing to remember when wiring bars is to push first and only pull hard enough to take up the slack that you've pushed in. If your pulling hard you'll cut the sheath on the wires or worse yet cut them into. I've done at least 6 sets of these same bars. Just take your time and be patient.
Received 1,504 Likes
Ok. I went with the 1 1/4 bars 12". The wires are already run through. Does anyone have a pin out of the black 6 pin connector that plugs into the bike? Need the wire colors too. Will resplice the wires tonight. I'm glad I can change the length of those wires without messing it up. Thanks
Good luck with your 'fix' to bad you now have to re-do what you paid him for
