When to replace your harley battery ?
Replace it if you ever fully discharge it to the level it won't crank the starter.
Then for good measure, I replace mine every three to four years. They eventually fail..why wait for it to fail?
And put it on a battery tender anytime you are not riding for a few days. That's easy and cheap insurance.
The battery in my '02 lasted 7 years (it died on the battery tender over the winter), the battery in my '10 lasted 3 1/2 years (replaced when it didn't pass the voltage test), the battery in my '12 is original and looks like it will make it past 4 years.
Based on my experience, I would change batteries every 3 1/2 - 7 years. I can also agree with always using a battery tender.
You can tell when a battery should be replaced by checking the voltage drop across the battery. The voltage test is described in your service manual and is a pretty simply procedure.
I typically get 4-5yrs out of a battery, but I've had them fail after one season (OEM battery). I've had others last 7-8 years.
Battery technology and manufacturing processes aren't perfect. It's old technology and a lot of things can cause problems..especially the age of the battery when installed, and whether it has been properly formed (charged prior to installation) and stored.
Received 1,503 Likes
