Hot off the dyno
#'s look good to me.
Just wondering,,since you installed high compression pistons did your bike already have compression releases & didnt mention it or does the motor not have compression releases which can be an issue esp restarts in hot weather if starter & battery arent fresh /strong working @ 95-100% capacity.
Scott
Scott
The heavy valve springs are unneeded and may cause more wear and stress than by doing good. Also may hold back the build without headwork to support them. Overall not bad but you really only have what cams usually will deliver for power and add a couple ft lbs tq for the compression compared to stock. Not raining on parade but a 107 would have been likely cheaper and better performance. Just cams,good pipe and air cleaner on my 103 dyna was 93/107 sae. Either way enjoy the ride.
I'm getting ready to try the TTS 100 cam with my stock headed and piston bike and am hoping for some close numbers. I was thinking of that kit but didn't want to do pistons if I didn't have to. I'm afraid that once the heads are off I won't be able to stop.
I understand STD numbers are about 3 or 4 ft/lb and hp more than SAE so just trying to compare. Here is a sheet off a stock headed and stock comp 103 with the TTS 100 using the SAE scale. Hoping for close.
