Hot off the dyno
Interesting.
__________________
HILLSIDE MOTORCYCLE & MACHINE, INC.
HARLEY-DAVIDSON SPEED & SERVICE CENTER
5225 SOUTH MAIN ST., MUNNSVILLE, N.Y. 13409
Sales/Support 315-495-6650
www.hillsidecycle.com
Walk-in Retail Showroom
Complete H-D Machine Shop
Case & cylinder boring
Complete Cylinder Head Shop
High-Performance Engine Kits
Crank Rebuilding
Direct Link & PowerVision Tuning
Goodson HD Tooling Manufacturer
Maxton Mile World Record
4500 sq ft. facility
OVER 35 YEARS OF H-D ENGINE BUILDING.
See us on Facebook.
Crank Rebuilding
See us on Facebook.
The heavy valve springs are unneeded and may cause more wear and stress than by doing good. Also may hold back the build without headwork to support them. Overall not bad but you really only have what cams usually will deliver for power and add a couple ft lbs tq for the compression compared to stock. Not raining on parade but a 107 would have been likely cheaper and better performance. Just cams,good pipe and air cleaner on my 103 dyna was 93/107 sae. Either way enjoy the ride.
I'm getting ready to try the TTS 100 cam with my stock headed and piston bike and am hoping for some close numbers. I was thinking of that kit but didn't want to do pistons if I didn't have to. I'm afraid that once the heads are off I won't be able to stop.
I understand STD numbers are about 3 or 4 ft/lb and hp more than SAE so just trying to compare. Here is a sheet off a stock headed and stock comp 103 with the TTS 100 using the SAE scale. Hoping for close.
Attachment 459774
Attachment 459774
Received 47,791 Likes
Sorry left out a word. Exhaust has been changed as stated in the dyno sheets. OP also has 10.5 to 1 pistons.
110 TQ with air and exhaust mods.
120 TQ with high lift cams, 10.5 to 1 pistons and exhaust and air mods.
