Widest Rear Tire on 2008?
Hey guys, your help is appreciated as I've heard some conflicting answers on this.
What's the widest tire I can put on the back of my 2008 RK without needing to modify anything (including trimming the belt guard).
I've heard 150 and 160.
Also, while I'm here, what's a good tire size to put on an 18" Airstrike front wheel I just picked up?
Thanks
-T
Thanks
-T
Can't answer about the front one. For the rear I was able to fit a 160B16 Dunlop E3. But it was a major PITA to mount it on the stock 3 inch rim and even harder to get it to inflate. Part of that was my fault as I still mount tires by hand using tire irons and rim protectors. I know Im cheap but Id rather buy other stuff for the bike as opposed to a tire changer.
No trimming was required. Once that tire was worn out I mounted a Dunlop American Elite in a 150B16 size. It mounted much easier. Again no trimming was required. And I am still running that tire without issues. My bike is an 07. 08 has the same swingarm. Both tires were a definite improvement over the stock tires.
Good luck
Good luck
150/80 for the rear, however take care with selecting the correct load range, you need around 76/77 and H speed range. That size is popular on older sports bikes and can also be had in lighter load range, also V speed range, neither of which you want.
The stock size for the 18" front is 130/70, which is the size I use. I also have a 160/70x17" rear, however that is not a bolt-in.
Thanks
-T
Thanks
-T
180/18 if you want to do a little work.
