Breather by- pass
No help
After reading the entire thread a second time, I found nothing on doing the bi- pass on a stock a c. My Indy says don't bother, since I get no oil in my air box . I'm going to do it anyway, for all the obvious reasons. I figured out how to do it for about ten bucks, and it will be invisible. I'll submit a full report when it's done.
If:
you found nothing
there is no oil in the air box
What are "all the obvious reason"???
How about the obvious reason that the scavenging through the intake of the crankcase is actually an important function of engine performance? When the crankcase sees negative pressure, there is actually an increase in engine performance. Positive crankcase pressure is bad.
