Brembo Caliper Rebuild Kit
Why do you need to replace the pistons? There should be absolutely no reason for those to go bad unless they got butchered during removal. Ive rebuilt a dozen calipers and the only thing I ever had to do was polish the pistons with a scotch bright pad. Seals is all you should ever need.
Yup I did miss that. Well Id have to assume the 08 Ultra already has a functioning caliper on it, and if he is looking to have the set he picked up painted, why couldnt he use the pistons out of the functioning calipers? Id prefer to have an HD part in there if it were mine over a drag part, especially when it comes to brakes. Id also advise to go powder coat not paint, the brake fluid will eat the paint off whenever they get bled or serviced.
Received 47,737 Likes
Maybe I'm overstating the obvious? ... Why not just pull your calipers off and paint them? It would be a whole lot cheaper than buying MORE parts. If you take care on disassembly ( assuming that you're not having problems with the calipers that are on your scooter ) you could even reassemble with the seals and pistons that are in the calipers now. I've done it many times successfully.
There seems to be conflicting info as to what fits or is available.
Drag lists front 1702-0119 and rear 1702-0120 for kits c/w pistons
I also see on this forum that the Drag kit did not fit for one rider but I did make note of the date
Any update and link on where I can buy kits for all 3 calipers would be greatly appreciated
I do have complete calipers with pistons, but did not know that the touring Brembos were different - thanks
I want the pistons simply because I do not like to do half a job if it can be avoided. I just did my old Bonnie and as you say the pistons were fine but I now know it is fine.
Money well wasted, but no point pissing about with brakes.
I see on the new that a Honda seal will fit
Are Touring and Dyna seals the same? I imagine that if the calipers are different, that difference would be in piston size
Does anyone know the piston sizes front and rear, for an 08 Road King
Now where to buy a complete kit, or even just the seals for a 08 Road King
You might be able to match up the seals at a "hydraulics" house.
Also Bumpandrun made reference to Honda seals "working" Here:
https://www.hdforums.com/forum/touri...l#post15284406
L/S 43027-08
R/S 44023-08
That lends credence to using the Honda 32mm seals but I would really like to know for sure before I start
