Brembo Caliper Rebuild Kit
I now am getting so confused with the various claims on the net and FleaBay about what fits
Do the Touring models use the same calipers as the Dynas and Softails
If not is the difference in the piston size?
Do touring Brembos have 32mm pistons?
Haven't measured the pistons to give you an answer.
You might be able to match up the seals at a "hydraulics" house.
Also Bumpandrun made reference to Honda seals "working" Here:
https://www.hdforums.com/forum/touri...l#post15284406
I have been trying to avoid using anything but the proper seal, but then again it is entirely possible that the Honda part is the same. I would just rather not
I could try pushing out the pistons as much as I dare, cleaning, and pushing them back in. I wonder if that spray on brake cleaner would hurt the seals - after all it is made for cleaning brakes but seems like pretty strong stuff.
