Just spoke with Tommy at CyclePro. They were the last to offer a Brembo rebuild kit but they are out of stock. He said demand for his kits went through the roof. He thinks he will be shipping in a week.
If I ever get my rebuild done I'm keeping the old seals to look for a generic substitute. I'm seeing a side to Brembo I don't like. I think they have put a cease and desist on aftermarket suppliers.
Went thru this a year back. No more rebuild kits available for the Brembos (unless there has been a recent development).
Need to buy a whole caliper now. IRT 08-13 touring at least.
I bought QTM rebuild kit last march when I did mine.
Was advised on another board that ebay does have them. Search Harley Brembo caliper rebuild seal kit. ***** Shiny has them.
I snapped a quick shot of them. The Honda seal has a larger diameter and if you look at the shadow carefully you can see the cyclepro seal is slightly thicker. I'll take a better shot once I have a caliper open.
Honda 45209-961-006 on left CyclePro 19257 on right
That's interesting...I've seen the 45209-961-006 posted by different people.
Let's hope a seal from CyclePro CP# 19257 kits matches your Brembo
When you get them apart, can you take a photo of the brembo vs the honda?
The CyclePro seals match the factory in size. The material is a bit stiffer. The kits come with aluminium pistons, the stock brembos appear to be plastic.
Let's put this Honda part number rumor to rest. Here's Honda p/n 45209-961-006 with the factory Brembo piston. It's obvious this doesn't fit. This came in an unopened Honda envelope stamped with the part number.
