To bleed or not to bleed?
Budda109 (03-05-2016)
Can't emphasize this too much: Put a piece of plastic over the gas tank and any painted surfaces in close proximity to that cap. That brake fluid has a way of jumping out of the reservoir onto painted surfaces. Like the other guy said too, turn the forks to the left.
Bleeding ABS Brakes
First bike I have owned with ABS brakes. I'll be removing the stock clutch & front brake master cylinders and replacing them with chrome ones sometime in the next couple of weeks. The instructions and repair manual indicate the ABS brakes can only be successfully bled using the Digital Technician II. The only way to bleed ABS brakes is to take the bike to the dealer and have them do it?? Anyone have an alternative method that works?
Any input is appreciated.
I do this at least once a year with most of my vehicles,suck out the reservoir with a turkey baster and refill with fresh fluid,as others have posted cover up before removing that cover!
