Dead battery now bike is dead
2012 Ultra started to go for a ride in November of 2015 bike turned over once then I got the clicking noise that indicates a dead battery. Pulled the battery that day and the bike has sat without a battery from mid November 2015 through today's date March 12 2016. Bought a Duracell ultra battery today from the batteries and bulbs store . Got home and installed the new battery and turn the ignition on and nothing happens , it's like it doesn't even have a battery in it. Checked the main fuse and the fuse labeled battery both are good . Hooked a battery charger up to the battery set at 12 volts 15 amps green light showing fully charged, when I plug the battery tender up it is giving me the solid red light which indicates the battery is charging and it has been solid red for the last 30 minutes. Any suggestions about what is wrong? Any help
is appreciated .
is appreciated .
Do you have a volt meter? If so just measure the voltage across the battery terminals.
Some times Battery cables can corrode in two underneath the insulation.Take the cables loose from the battery and ohm them out. Positive to the starter and negative to the ground on the transmission case.
