Compensating Sprocket Bolt Removal Trouble
I'm having some trouble breaking the compensating sprocket bolt loose on my 2016 RGS. It's a T-70 Torx bolt that's torqued to 175 ft-lbs and probably covered in Red Loctite...so I know it's definitely gonna be a bitch to break loose. I've followed all of the steps in the service manual so far but I'm stuck at the compensating sprocket bolt:
I have everything all set up like the picture above illustrates. I hit the bolt with some PB Blaster and I also took a torch to it briefly and nothing. I've never disassembled the inner primary before, but something just does not feel right. It feels like the engine is moving as I'm wrenching on the bolt counterclockwise. The clutch side broke loose no problem (granted it's only torqued to 70-80 ft-lbs). The sliding cam (#5 in the picture below) is moving slightly the more pressure I apply:
What the hell am I doing wrong? Or is this completely normal and I'm just being paranoid?
Don't bother with heat. Just too much metal on the whole assembly to do any good.
For the record if it's never been broken loose before, it's a blue/grayish lock tight.
Get out a breaker bar and go for it. You won't break anything - it's tough.
Replace that bolt when you go to reassemble...
Completely normal. You are going to have to put some *** into it big time to break it loose.
Realize that we are all a long way from your problem but I think that big torx is probably tighter than a bulls *** at fly time, so to speak. Get a long breaker bar and grunt till you soil your pants if you have to. It will come loose. Ya, your probably are a little paranoid but we have all been there a few times.
