2007 flhtc Michelin tires has my head spinning
So it is time for new tires and after reading and searching this site for answers my brain is dead (maybe the TBI), the stock front D402f MT90B16 is from what I found is the equivalent to 130/90-16 which is in the Michelin commander II size, now the rear D402 MU85B16 is 140/85-16 but the Michelin commander II does not come in that size, it comes in 140/80-16 and 140/90-16, I called the dealership and they said they have the right size commander II for my bike but the number was MU85B16 which is the stock dunlap number and not Michelin?????, can I put the 80 or 90 on my 2007 electra glide classic with out any problems or will there be rubbing or other fitment problems? I have dunlops on now but after reading the reviews of the Commander II I kinda have my heart set on them, and do you have any suggestions on brake rotors since I will have the tires off?
m74cran (03-15-2016)
Received 1,504 Likes
I sort of agree with raven. It's actually 1/2". The 80 and 90 is the sidewall height as a percentage of the width - the 140 in mm. The 90 might be a little cushier as the height is 14mm more than the 80.
Unless you bottom out quite a bit, then go with the 140/80. The 140/90 is about an 1" bigger in diameter.
The designations MT90B16, MU85B16 are US tyre specs, which are the same as 130/90B16 and 140/85B16 International specs. As an alternative you could consider 150/80B16, which will also fit your spec bike.
Have you thought to look at the Michelin website?! According to my reading of it, they offer the Commander 2 in 130/90, 140/90 and 150/80. They also offer the H-D Scorcher 31 in 150/80B16
Thank you guys, I think the 140/90HB-16 is the tire that will fit my bike the best, there is not much room between the side of the tire and my fender and while doing some more research I stumbled across this https://tiresize.com/comparison/, I entered a couple different sizes and I figure I can spare the height but not the width (there goes my lowering kit), but I am not yet ready to pull the trigger on this, I might restart my tire search and change my mind on the Commaned II's but we will see.
