Rider Backrest Repair
Old 03-25-2016, 02:12 PM
lowriderjim's Avatar
lowriderjim
lowriderjim is offline
Default Rider Backrest Repair
I have a Harley rider backrest. The spring that holds the tension forward is appears to be broken. It looks to me that I will have to remove the cover to access this spring. I can't tell where the top of the spring attaches.
Does anyone have any experience with this problem?
Old 03-25-2016, 02:34 PM
shooter5074's Avatar
shooter5074
shooter5074 is offline
Location: Western Illinois, land of bad roads, and corrupt politicians
It probably just came unhooked. It happened to mine. Just go to your dealer and ask to see a backrest, to see how it's hooked. You can lift the slit in the back to see it. You can re-hook it with a pair of needle nose pliars
Old 03-25-2016, 04:27 PM
lowriderjim
Thank you for the reply. The loose end does not have a hook. It is a straight end which led me to believe that it is broken but I have not been able to find where it attached. I was at the dealer today but only determined that a spring was part of the assy. I plan on returning to the dealer tomorrow. The parts sheet only shows the spring that goes between the installation uprights.
Old 03-25-2016, 05:42 PM
shooter5074
The spring just keeps the backrest from flopping around when you are not leaning back into it.
With that said........ how many times are you going to be going down the road when you are NOT going to be leaning back on it ?
Old 03-25-2016, 06:52 PM
lowriderjim
This may help. I will mount it on the bike and go from there. Thanks for your help.
DC3TP
02-03-2019 01:14 PM
dh_meyer
2014-2023 Touring Models
05-20-2015 05:56 PM
10350
08-18-2011 05:02 PM
gearheadfmc
01-06-2008 09:46 AM
zlaneb
10-19-2006 12:12 PM
Quick Reply: Rider Backrest Repair
