Shifter Shaft HELP
04-11-2016, 06:19 AM
Shifter Shaft HELP
I had a leaking seal at the shifter shaft and pulled it a part to replace. Everything has gone well, purchaced the proper tool to install the seal. My problem is, The shifter shaft itself has moved into the transmission some. Once I place the washer over the shaft there is no longer any room to put the snap ring on. I tried pulling on the shaft to move it out and it won't budge. Has anyone else run into this or do you have any solutions?
Thanks in advance for your help...
04-11-2016, 09:25 AM
Put your lever back on and rotate shaft while pulling outward. Did you lube new seal before seating it in place?
04-11-2016, 09:45 AM
You must be mechanically inclined. pop the top of the trans.
04-11-2016, 09:48 AM
Yes I lubed both the inside and outside of the seal. I will try putting the lever on as you suggested. Thanks
04-11-2016, 09:59 AM
I was wondering if I could get to it through the top cover. Thanks, I will give that a try.
04-11-2016, 05:59 PM
Quote:
Originally Posted by
Eunoterpsia
Thanks for the tip. Worked perfect, everything is now lined up and the retaining ring is installed. Thanks again
monkey sammich
06-15-2021 12:20 AM
LQQK_OUT
09-06-2017 03:19 PM
TeeStu
06-23-2015 07:45 PM
albngore
01-10-2012 08:44 PM
Harley58
08-21-2011 07:22 PM
