Oil Leak at Stator Wires
I have an oil leak at the front of my engine where the stator wires come out the primary case. (I have the Twin Cam engine) I think this is a common problem.
How do you fix it? Well the wires are encased in the rubber that should seal the hole. The wires are attached to the stator. So the right way to repair the leak is to replace the stator. This is an expensive little leak. According to the Harley Dealer it's:
Stator $164
Gasket $36
Tax $16
Total $216
Plus this is no small task. You have to remove the primary chain, compensator and stator. That's time consuming if you do it yourself or expensive if you pay someone to do it for you.
If that's the right way is there another way? Many Harley owners just let it go and add oil as necessary. The leak is in the bottom front so it doesn't really mess up the cycle or engine. I think this poorly designed oil seal is one of the main reasons Harleys have the reputation of "marking their spot".
Has anyone ever successfully addressed this leak without spending all this money and time?
That rubber that is leaking is soft. I can compress it with my finger, opening the gap more. I know there isn't much pressure on this seal but every engine built now a days has wires that need to go inside. Other manufacturers are able to keep it sealed.
Stator $164
Gasket $36
Tax $16
Total $216
Clean it real good with brake cleaner. Let it dry. Seal it up with some black rtv gasket/sealant. I used Permatex Ultra Black Gasket Maker. Says on the label Maximum Oil Resistance. Stand back after the repair and you cant even tell its on there. Mine started leaking right after my ace mechanic had the primary apart so I did this instead of tearing it apart again. Its been a year no with no sign of a leak.
why not release the tension on the wire but cutting the zip tie. Then flush the entire area with brake cleaner and the see if that release in tension prevents the leak. If not... then apply a very very small amount of permatex as others have suggested.
Last edited by Eunoterpsia; 04-13-2016 at 09:01 PM. Reason: to correct a spelling issue.
Thanks guys. I think I'll try the brake cleaner followed by the Permatex with Maximum Oil Resistance. It may be postponing the inevitable but I'd rather do that 4 times instead of replacing the stator twice before a rebuild.
I put on a lot of miles (17K last year) and I want to keep this engine going without tearing it apart every year or two.
Oh and there really isn't any tension on these wires. They are loose after exiting the engine.
Stator $164
Gasket $36
Tax $16
Total $216
Stator $164
Gasket $36
Tax $16
Total $216
Durango Dave (04-13-2016)
