A solution for checking air in rear bagger tires
Checking the air in the rear tire of a bagger has always been a PITA, but my 2014 Road King is the worst yet. The idiot that designed the laced wheel put the valve stem so close to one of the spokes, that getting to it is almost impossible. Especially from the right side. So after lots of experimenting and ordering of various adapters, tees, fittings, hoses, etc. I've come up with a solution.
The two items you need I ordered from Amazon. First, you need this lossless 90-degree fitting:
Second, you need this hose:
To begin, it's easier to have the right saddlebag removed and position the valve stem at 6:00. Attach the Topeak adapter to the Wheelmasters hose.
Using your left hand, fish the hose/adapter combo from the left side of the bike to as close to the valve stem as possible.
Then use your right hand to tighten the fitting onto the valve stem.
The Wheelmasters hose is long enough that you can now easily check your tire pressure and add air if needed.
The lossless Topeak fitting will let very little air out when you remove it.
http://www.amazon.com/Topeak-Pressure-Rite-Anti-Air-Loss-Connector/dp/B000FIAVKG/ref=sr_1_19?ie=UTF8&qid=1462124753&sr=8-19&keywords=schrader+90+degree
http://www.amazon.com/Wheel-Masters-82286R-Spare-Inflator/dp/B001FCE63E?ie=UTF8&psc=1&redirect=true&ref_=oh_aui_detailpage_o03_s00
The following 4 users liked this post by JonW:
I did similar, made from a cut off valve stem & a Walmart bicycle pump...
Got the idea from another member here.
For ROCKOUT information & purchasing please click the LINKS below...
__________________
NO, they DON'T all do that!
Also on amazon.com...
Received 2,524 Likes
Received 1,503 Likes
