can't tighten front fork bottoming cup bolt
I'm in the middle of installing Progressive monotube front shocks, and I can't get the bolt that secures the bottoming cup to tighten. I've got it in place, but the cup is just spinning inside the lower so I can't properly torque it. Any suggestions???
At the end of the day keep the OEM set up and change to heavier oil, same effect.
Clean the inside out real well with brake clean or something. Then when you put the cup and tube and what not in screw the top cap into the slider a ways, flip it over the hand thread in the 6mm bolt, the when tight torque it down while applying pressure on it while it is upside down and that tube deal is on a piece of wood or something on the ground. You used the correct cup right? Mine called for stock bottom cup.
I wouldn't hit it with the impact gun unless you have one of those rattle sockets that limits torque or you damage something or never get it loose. Use impact to remove not install. You will need air to get the required torque value, regular battery drill on impact setting I have found to have enough umph to remove screw but not enough power for get proper torque.
There's no air in these monotubes.
Good to know, cause I used an impact to tighten the left leg when doing my monotubes (-1"). Torque wrench verified that it was between allowable torque spec. I figured that it wouldn't over tighten due to the spinning as well. They ride great and really appreciate the limited fork dive, especially when riding two up.
