Start gear replacement.
I need a new starter gear for my oem starter on my 08 SG. I see replacements online but haven't been able to find any threads if its possible to swap just the gear on a factory starter. I recently replaced my compensator and saw the starter gear chewed up but the big ring gear is ok. Thanks in advance!
Put this one on my 08 SG about 35000 miles ago, so far so good.
http://www.directcycleparts.com/elec...in-p-6908.html
ls1crazy01 (05-06-2016)
Starter needs to be disassembled to replace gear easy job. disconnect battery and pull starter. Have a table or bench and lay your parts out how you remove in a line clean the starter up and reassemble make sure to get the new o ring. for the head of the starter for the primary cover so you don't have to remove it again for a leak.
The whole starter drive is a little more complicated but you can get these and maybe do it from inside the outer primary. If not just pull the starter and not disassemble it.
31345-06 gear
31328-91 retaining ring
Here is a good link to have.
http://partsfinder.onlinemicrofiche.....asp?make=hdmc
31345-06 gear
Best to have service manual handy, also try to take a razor blade and cut the powder coat on the starter where it comes apart to avoid chipping it off. Avoid pulling the armature out of the starter at all costs, it doesn't need to come out to replace the starter clutch and a lot more work is involved should you pull it out by accident.
This is one I wrote up for my 09. I think the 08 and before starters may have a screw holding them in under the primary but the starter I would think would come apart about the same. Pretty easy job. Good luck!
https://www.hdforums.com/forum/touring-models/699634-starter-clutch-replacement-on-09-sg.html
ls1crazy01 (05-09-2016)
JustDave71
05-05-2010 12:18 AM
