Brake lights steady on..
Old 05-23-2016, 02:53 PM
jamesdeanblvd's Avatar
jamesdeanblvd
jamesdeanblvd is offline
Default Brake lights steady on..
I've got an 07 ultra and the brake lights are staying on all the time. Changed bulb to new LED replacement and still stay on. Any ideas on tracking down. Couldn't find anything in service manual.
Old 05-23-2016, 03:08 PM
decencyxdefied's Avatar
decencyxdefied
decencyxdefied is offline
Did u do anything to the bars, if so it could be the brake light switch
Old 05-23-2016, 03:15 PM
Don81's Avatar
Don81
Don81 is offline
Unplug your rear brake switch and see if that turns it off. If not, it's the front. Check the switches to see if they're sticky or broken.
Old 05-23-2016, 04:07 PM
69cj's Avatar
69cj
69cj is offline
The front brake switch was very touchy on my 07.
Old 05-23-2016, 06:16 PM
voodoodrug's Avatar
voodoodrug
voodoodrug is offline
just rebuilt my master cylinder to fix this.
Old 05-23-2016, 07:28 PM
ORradtech's Avatar
ORradtech
ORradtech is offline
Yep, me too. Though I was able to push the lever away from the grip and it would go off. Don't know if I had a weak spring or a gummed up piston but rebuilding fixed it.
If you decide to do the front be careful to use a shim between the switch and the le er or you can break the switch.
Old 05-23-2016, 08:16 PM
FLHTCU Owner's Avatar
FLHTCU Owner
FLHTCU Owner is offline
When my 07 did that, it was the rear brake switch.
Old 05-23-2016, 08:38 PM
jamesdeanblvd
Ok. I'm really starting to think I'm losing it. Checked the rear switch and no change. I'm trying to find the front switch.. Service manual doesn't show it, like it does the rear, unless I've missed it. Thanks for the help.
Old 05-23-2016, 08:42 PM
TheGrandPoohBah's Avatar
TheGrandPoohBah
TheGrandPoohBah is offline
Received 2,524 Likes on 1,421 Posts
You are halfway finished.
Good luck!
I am thinking it's one or the other, too.
Old 05-23-2016, 08:44 PM
jamesdeanblvd
Woops.. Think I found it. Have to partially disassemble housing.
Quick Reply: Brake lights steady on..
