Misfiring
Misfiring
Ok have a question for you mechanical types.
I replaced the cams in my bike and upgraded the bearings along with putting on some full dresser duals since I took the exhaust off. Used some S&S quickee adjustable pushrods in there and am pretty sure I had the turns right on them.
Problem is that after I got it all back together it misfires at all RPM ranges on me. I am about to open her back up to diagnose, but I am a simple DIYer and this is my first engine job.
I have pulled plugs and saw no build up and the porcelain is good on them, so guessing from there its' not the plugs (or maybe the wire too based on that?).
It's a 2011 Road King Classic with the 103 and Stage 1 (high flow air cleaner and V&H big oval slip ons). Other than that it is pretty bone stock besides my newly added cams.
So what would cause the misfire? Anything I should be looking for in there that would cause this?
Thanks in advance!
Thanks in advance!
If it were me I'd install a new set of plugs. Make sure you installed the push rods in the proper places.The intake and exhaust push rods are different lengths. Check that too. Cam timing may also be off 1 tooth. How long has the bike been sitting. Could be a fuel issue. What kind of tuner are you using? Do you even have a tuner? Thats all I have but there are many here smarter than me that can help out too. Hope this helps.
I made sure cams were right on timing-wise about 10 times.
Bike was sitting less than a week, so doubt it was fuel issue.
No tuner at the moment, but was going to get dyno tuned once I get it running. I have noticed it is making a noise doesn't sound normal from either the lifters or pushrods. So I was going to pull the pushrods tonight and redo them to be sure.
without some kind of tuning the fuel delivery AND ignition timing won't be correct for your motor.
it just will not be.
so you now have the possibilities of
wrong fuel delivery
wring spark timing
wrong valve timing/lift
add the characteristics of your new pipes, and if other than stock type the plugs and wires ( see ion sense)
misfiring can be a result of so many things that an experienced hand may have trouble telling the cause of the fault- too much fuel, too little fuel, valve held open...or closed or not enough ( all cam/pushrod) air leaks- confused ecm etc etc etc
mike
wrong fuel delivery
wring spark timing
mike
