Passing Lights on High Beam Mod
Does anyone know of a pic tutorial or video on switching the connector wires to keep your passing lights on during high beam? I have the wiring diagram that gets posted here, but I need something a little easier to follow. Wiring is not my area of expertise. Thanks for the help.
diy mods sticky above has 300 posts on doing this- some require buying an adapter...some soldering or other method.
mine took 60¢ and 3 minutes
there are maybe 1000 poss of the garage door opener- some easy, some hard some cheap...
that sticky is really worth a read from start when you have time to kill
mike
mike
Received 47,785 Likes
Thanks. This is the diagram I've seen before, but this is the first time I think I understand it. It looks like I can access this by just pulling the switch dash... correct? Also, I just remembered I'm not using my front fender tip light wire because I replaced the front fender with a non-lighted RG fender. That wire is just tucked up inside and could easily be re-routed to the passing lamp switch. Does that sound like it might also work? I seem to remember the fender tip light as always being on with the ignition switch.
Uncle Larry (06-04-2016)
Again, I'm not that experienced in wiring. Can someone recommend the best method for connecting the yellow wire to the orange/red wire in the diagram?
Is there some kind of snap-on connector that will tie the two wires together by piercing the insulation? Or, will I need to trim back a section of the insulation to tie it in?
Thanks
Thanks
